dpmac
- Nov 11, 2003
- 148
A number of years ago we installed a basic Eaton ATC-600 IQ Transfer Controller in an older GE 5kV line up. The customer wanted Option 29J (Manual Transfer Back to Normal rather than the standard Automatic return.) The option was installed via a Option Feature Module via serial port. The controller crapped out after 13 years. Customer has a replacement controller and Option 29J feature module. I just can't seem to locate instructions for installing the option into the controller. I have scoured the am surprised I can't find the instructions. The controller is discontinued so Eaton has been slow to respond. My distributor can't do anything without the original Eaton SUM number which does not exist as the controller was installed in GE gear. My good Eaton contact has moved on so I am hoping to get lucky by posting here. Any help would be appreciated. Thank you.
