Edge Blend For a Swept Surface 1
Andrew Rowe
I'm attempting to blend the front edge of this swept surface. It was a rectangle that I swept along the path of a spline. I would like to make the edges of this surface curved. Is there a better function I should be using other than edge blend or am I just using it wrong? Picture for reference.
You may have to do 1 edge of that block at a time due to the sharp corners
In the swept option there is a toggle called preserve shape, make sure this is toggled on. If you do not toggle this on, NX makes the edges a little bit rounded and it can not be filleted. Just a thought. Thanks
