edit expression check
multicaduser
Industrial
Jan 29, 2013
261
It's easy to create an expression check, but how can they be deleted or edited? The image shows a list of acceptable values so the checks can be displayed, but how to edit the list? I know there are other ways to do this, right now it's just an exercise in trying to find out the limitations of this option.
tia
NX 1899 Windows 10
Hi Tia,
I had the same issue and thought I'd share my findings. 🎁
I just found that you can access the checks via Analysis: Requirements Validation
Hopefully you can work out how to edit and delete from there. 🙂
Tnx @RX8UK, just found this the day before Thanksgiving, checks can be deleted from here (see image below). Sometimes I'm just blind.
NX 1899 Windows 10
