Hi guys, facing a bit of a problem here. Please see the system layout here :
I've connected an eductor to the coolant pump in my machine. This eductor sucks the leaked cutting fluid from a tray underneath the machine I.e coolant passes through the venturi(let's call it motive) and returns to the tank and in this process a vacuum is developed which is used to suck up the oil from the tray which travels with the motive and enters my tank.
Now the problem I'm facing here is once all the leakage oil has been sucked up the device keeps sucking air which is then effectively injected into the coolant sump thereby causing a lot of foam. How can I prevent air from entering the tank? I cannot use any timers or solenoids to turn off the system. Need a simple mechanical suggestion please. Currently the pipe is inserted into the coolant to ensure it does not spray coolant all over the place. Will clamping this pipe above the coolant level help?
