EES (Engineering Equation Solver)
andradesilva
Materials
PT
I derived a 4th degree equation that I am using in EES (Engineering Equation Solver). The system solves very well, but when I try to add my equation, which is a 4th degree equation, the software gives the error that I show in the picture that attach to this post. The equation is A = 102369 - 3.06e11*B^4
The unknown is B. A is a known scalar, and I checked its value. It's correct. The equation is well derived, I already checked it. The .EES file runs without problems if I change the equation to a 1st degree one, resulting, of course, in totally wrong results.
Can someone tell me what can be going on?
Thank you,
Best regards,
I am not sure, but in general systems of equations can be solved in a stable manner if each equation is expressed to a power less than or equal to 1. Try rewriting the equation as B=(102369-A)^.25
I saw no picture attached.
A syntax error? Try A = 102369 - 3.06e11*B**4
Is it 3.06E11 or 3.06E-11?
Good Luck,
Latexman
Conversely
B = {(102369 - A)/(3.06e11)}^0.25, or **0.25 if that's the syntax
Mathcad's solver has occasionally burped and needed to get a different expression of the equations to get it to work.
I think that linearizing the unknown usually makes the solver happier. Anything higher order than 2 results in multiple roots that can cause problems if they are too close together.
TTFN (ta ta for now)
IRstuff conversed equation is correct but be careful about A not being greater than 102,369 which may explain the error in EES.
It seems that the OP's equation was derived from a regression analysis; is that correct?
Hi!
Thank you very much for the help.
Mr. Davefitz:
I revised the equation to the one you suggested. I got this error: Run 1: This equation atttempts to raise a negative number to a non-integer power
Mr. Latexman
I tried to use ** instead of ^ for the exponent. Same error appears in both cases: Run 1: This equation atttempts to raise a negative number to a non-integer power
Mr. IRSstuff
I think that if { and/or } are used elsewhere, the characters in-between are not recognized by the EES solver as equations. I tried it and I get a sintax error.
Mr. chicopee,
Yes, this equation was derived from data obtained from experimental tests in the company I work.
Are there any other suggestions?
Thank you all once again,
Best regards,
Is A larger than 102369, then? That would seem to be problematic. Can you start A with a smaller value? Have you graphed all the equations to see if they make sense?
