Dear All,
according to AISI, 430 grade should have 1.2 % of AL content, as well as ch15ju5 according to Russian Gost Standard.
because of some limitation in material supply, we are going to substitute 430 for ch15ju5. to do so, we took a sample from supplier of 430 stainless steel and have it elemental analysis. result shows that the sample 430 does not contain AL, but other elements are as ch15ju5.
intended application is that 430 stainless steel would be used as a resistive element in a grid brake resistor. the temperature would increase up to 750 Celsius for some moments. off course there will be a cooling fan to cool the elements of resistor.
would lack of AL be a matter? how does it affect the stainless steel?
any comment would really be appreciated.
best regards.
best regards.
