Hi All,
We had received SS 316L Rings (6” circular hollow ring) which will be used on Drilling Equipment as a retainer ring to hold packing elements. As per our client specification, all these Rings (100 No’s.) shall be hardness tested 100%.
However, from test records, it is observed that only 20% (20 No’s. on random sampling basis) has been hardness tested. When we contacted the supplier/manufacturer, they said that all these Rings are from the same heat treated lot and 20% testing would be suffice to justify the entire lot.
Moreover, all these Rings will be subjected to exterior skim cutting (2 mm machining) in our workshop.
My questions are:
Does “skim cutting or machining or any cold working after final heat treatment” affect hardness values ?
Does a light draw pass for size control impart some cold work to the outer surface which normally results in a slight increase in surface hardness ?
Does it require an additional heat treatment after skim cutting/machining/light draw pass to nullify the effect of cold working/strain hardening to control surface hardness?
Please advise.
My questions are:
Please advise.
