Dear All,
I am currently evaluating scenarios scenarios for existing pumping system,appreciate your feedback on the below:
A-Scenario A: pump has a shut off head as per pump curve, discharge system was elevated initially with a static head of 5 m.Then it was decided later to increase the static head to 15 meters, do you believe no change will occur to pump shut off as it is always a zero flow scenario. Can we say that pipeline pressure rating would not be impacted as long as it was designed for the pump's shut off pressure? In other words, during normal operation,flow delivered by pump would be less compared to original case as the system curve is now raised and intersects at lower flow with the pump curve which is independent of the static height.
B. Scenario -B if the receiving system on discharge is located at -20 meters elevation with respect to pump's eye. The design pressure of this system should take into account pump's shut off pressure (shut off head at maximum density) + the static height of 20 meters with maximum density?
C. Scenario-C : I was discussing with one of the engineers on the adequacy check of en existing system pressure rating post upgrading pump's impeller. Bigger pump impeller yield higher shut off head. Hence with the use of the maximum density shut off pressure is estimated. I believe there is additional need to add the maximum system's suction pressure (design pressure of upstream suction) and the suction maximum static height to the estimated shut off pressure from pump curve...The engineer was stating that the blocked in discharge will lead the upstream suction side to reach its design pressure kindly please advise. In all cases,it shall be assured the shut off head on pump curve is with a rise of at least 10% from the rated head.
Thank you very much,
