Structural.1997
What do you typically use as the effective length of your foundation walls and piers? Do you consider the stabilizing effects of the confining soil?
I have always neglected the contribution of the soil and treated the piers as if they were columns above grade. Much of my work is in Canada where frost depths typically result in shallow foundations over 3m deep. Completely neglecting the lateral bearing capacity of the soil to prevent buckling and bending of the piers and foundation walls sometimes this seems over conservative.
Assuming the pier acts as an unbraced cantilever column would give k=2, am I able to reduce this by considering the effect of the soil compacted around the pier and do you recommend any references relating to this?
Thank you!
Thank you!
