Hi.
I am currently working for bridge design. For steel bridges truss, the client want to model each gusset connection in FEM. Just like I-35W Bridge Gusset Failure FEM.
They want to see the gusset plate stress, and the bolt stress. The load is static elastic for some case due vehicle load or moving load if it could to get the maximum forces at each member that connected to gusset.
I propose to use shell for gusset and the beam for the bolt, that connected via spider compression only link to get bearing pressure to the hole plate, and some stiff link for stabilize around near hole for bolt tension/compression/fix rotation. Since using compression only it will non linear situation. The gusset can be connected to truss-beam bridge whole structure using constraint rigid link at connected members.
But this quite take a while, sometimes non convergence.
If i use rigid link, like RBE2 spider it will static situation, but will not get real bearing stress at hole due shearing bolt, right?
So what the best one to efficiently get plate bearing stress at hole gusset?
