Mohamed haggag
Hi lads,
need advice here
we are building low voltage distribution panel to supply loads such as compressors, dryers, etc
the main supply will be from the utility and we use 1250A LOAD BREAK SWITCH, at the same time the same panel will be supplied from the emergency supply which will be the generator and we put 800A AS Incomer
what precautions should be in place to protect the panel from being supplied from both sources at the same time? for sure the generator breaker will be LOTO at all time unless we lose the main supply
any ideas? i will use the shunt trip coil. thanks
need advice here
