I have a machine in an enclosure with multiple doors and bolted panels. The machine itself has a 25A three-phase 480VAC fused disconnect, for driving two motors of respectively 1 and 5 HP. At the core of the machine is a gas turbine.
I'm actually pushing for having all doors and bolted panels bonded to the frame, which is to be grounded. IMO, they all should be, despite not having any electrical component mounted on them per se.
I have seen a few threads referring to judgment calls on this topic, but the very nature of the thing (gas lines inside) should vouch for the bonding.
Am I right in my assertion?
Thank you.
Thank you.
