Paul R
- Jan 30, 2019
- 6
Hi, I make guitar pickups. I'm not an EE. I've applied for a patent, and the patent examiner is having a hard time distinguishing the difference between a single coil twisted into a figure 8 shape and a pair of coils connected in series. I need some help making the case that these are significantly different things.
The figure 8 coil shares some properties with a pair of coils in series, the most important one being hum cancellation when each loop of the figure 8 (or each coil in the series pair) goes around a magnet of opposing polarity to the other. But it does not share other properties: mutual inductance and mutual capacitance, for example, are undefined... they have no meaning in a single coil. In a coil twisted into a figure 8 shape, each turn of the coil goes clockwise, then counter-clockwise. In a pair of coils in series, the turns go around one way thousands of times, then the other way thousands of times.
The figure 8 coil has a tone (when used as a guitar pickup) that sounds like a single coil. Two coils in series give a different sound, even when side by side so that each coil "picks up" different strings. That's not something I know how to quantify, and will vary depending on any number of factors, so it's not a particularly useful argument.
Is there anything else you can think of that would help make the case that one coil twisted into a figure 8 shape is not the same as two coils in series? I'd love to have a simple, unrefutable scientific argument in clear electronic terms. I'd like something more "solid" than just that certain qualities are undefined.
Can you help? Thank you.
