tdawgye
- Mar 19, 2020
- 18
Hi There,
How you design elevator hoist beams? Do you only take into consideration just the car and passenger weight, or both plus the counter weight?
How do you design elevator pits? Do you only consider the buffer impact load plus the static load of the car, or both plus the vertical loads under guide rails?
Thanks, I appreciate any help.
