Hi Everyone,
We are designing a machine which has a rotating load that is rotated by hand wheel. The shaft has 250kgs on 1 side and then 300kgs on the other side as shown below.
It will be rotated by hand wheel 180degrees and then the load changes so that the extra 50 kgs is on the other side and then the loads is rotated back.
We have tried a gear box and this works when the rotation of the load is working against gravity but when we go past the Center of gravity and the load is working with gravity - we get what I believe is backlash in the gearbox (the load bounces around).
We need to eliminate this backlash - we dont have to have a gear box if there is another method but is there a way to eliminate the backlash?
