John Parnell
- Jan 11, 2020
- 6
First let me state that I am a mechanical engineer working to EMI shield an electrical instrument gauge. This gauge is much like the oil temperature gauge on a car. The shielding is in the form of a 2" diameter aluminum housing. The front of this housing is ITO coated glass for viewing the gauge, that is supposed to be well grounded to the aluminum housing with conductive epoxy. On the drawing we called out for the ITO to have a sheet resistance value of 20 Ohms/square or less. We then bought the housing assemblies from a vendor. The vendor sent us in a sample of housings that I had measured by an independent lab to have a sheet resistance of about 9 ohms/square. However, when I use a multimeter to measure the resistance from the center of the ITO coated glass to the housing I get values that range from 9 ohms to 150 ohms. We looked at the housings with the higher resistance values and noted that there seemed to be gaps in the conductive epoxy. This is not good for EMI shielding. During EMI qualification testing, we had used a case that had a measured value of about 10 ohms from the center of the 2" ITO coated glass to the case using a multimeter. That unit passed EMI testing and qualified us to begin production. Now I am wondering if I need to specify a resistance value of ITO coating back to the housing in order to properly qualify production units for use. If so, is this a proper method to specify that measuring using a multimeter between the case and the center of the ITO coating should be less than a certain value? What value should that be? What value should one expect, measuring resistance using a multimeter between the center of a 20 ohm/square ITO coating out to the 2" diameter of the aluminum housing if the housing is well grounded to the ITO coating? I cannot go back and retest cases for EMI, as these tests are hundreds of thousand of dollars. I also don't want to specify something that is impossible to deliver by using values that are too restrictive.
