emphasis
Terriers
1
I´m making a simulation with Abaqus 6.5 or 6.4. My body consists of 3 parts and I must variate the masses to change the emphasis and the moments of inertia. I searched in the documentation for an instruction for the emphasis announcement, but I only found an order in the module part tools query. But this order isn't what I'm needing, because no properties are considered and this option is only available for one part. It would be very kind of you if you could tell me how to indicate the emphasis/moments of inertia of assemblies. Or if that's possible at all? Abaqus computes it anyway!
So far I imported the parts in hypermesh for the analysis of the emphasis - however abaqus must be able to do this also. Thank you
with kind regards,
terriers
