MartinLe
- Oct 12, 2012
- 394
Three submersible pipes in paralell will feed a pipeline, lifting wastewater by about 7m and feeing into a tank (near the bottom). Sveveral instruments will be installed along the pipe, including a static mixer, flow meter, etc. I think it would be a good idea to be able to empty the pipe.
The medium is water, main pipe will be DN300.
There will likely be one high point, but no low points along the pipeline.
My first idea is to have a small ball valve at the manifold or similar to empty the pipeline into the sump. This seems straightforward, but I've never seen something like this, is there any problem with such a setup?
I'm not sure about the high point. Vacuum breaker valve? Smallish pipe with manual valve and open end straight upward? Take extra pains to avoid the high point (my curent preferred option)?
My problem with the vacuum breaker is that I have zero experience with these and that I want to avoid aditional maintenacne points. My problem with the second option (and maybe with the vacuum breaker, too) is that right now I have no place to put the pipe two where I can tolerate spillage and that's frost free. Any thoughts or aditional questions I should consider?
