May 4, 2003 #1 bslgeoff Chemical Nov 26, 2002 3 0 0 AU Hello Everybody Just seeking info on whether anybody out there know of some tin mills that use direct application of oil? Also if I could be directed to a website explaining ESI and how temperature effects can be determined. Thanks Geoff
May 5, 2003 #2 25362 Chemical Jan 5, 2003 4,826 0 0 CA If by ESI you mean emulsion stability index then by asking just that phrase from the internet you may find a lot of articles dealing with the subject. The same regarding colloidal mills. Good luck! Upvote 0 Downvote
