I have a client bringing skidded equipment into Canada from Europe. I'm doing a quick evaluation of the vendor's design methodology to make sure it generally complies with local requirements. They're using Canadian design codes and EN rated steels. I'm not overly concerned, because they're assuming a very low strength material that appears to just be bog standard mild steel. It's graded S235, which is a yield of 235MPa / 34ksi. The metallurgy is low carbon and I don't expect a welding problem unless there's something incompatible with our welding code that I'm not expecting. I can't see an issue with it.
The combined safety factors between the Eurocode and S16 appear reasonably similar, which would imply that variability is similar between our materials (EN 1993 has lower or negligible resistance factors on the materials, but load factors are slightly higher to the point where things are pretty similar)
I also suspect that the material they're using to build will have higher strength than their conservative design assumption, but I'm just concerned with evaluating their methodology.
Anyone who does work across jurisdictions see anything off in my assumptions here? For our American friends, Canadian codes are generally compatible with US structural steels, so feel free to have opinions regarding EN steels and US codes.
