I am studying EN 13445 Annex C: Design by analysis - Method based on stress categories.
Regarding primary local membrane stress (PL): ”At discontinuities, primary membrane stresses in shells are classified as local if the equivalent membrane stress exceeds 1,1 times the nominal design stress f and if the region in which this value is exceeded remains within the length of 1,0 (R * ea)^0.5 in the meridional direction.”
Question:
-So, if the equivalent membrane stress is e.g. 1,15 times the nominal design stress f then the stress is local. But if it is e.g. 1.05 times the nominal design stress f would it then be a general primary membrane stress -What is the meaning/purpose of this distinction?
There must be something I am misunderstanding here since if the stress level 1.15*f is categorized as PL then it is within admissible limit (<=1.5f) but if it is 1.05*f and therefore a general membrane stress it is categorized as Pm then it is not within admissible limit (<=f). So for such case the higher stress level would be ok but the lower level would not be ok.
Question:
-Do any of you have a sketch/reference which explains the area ”within the length of 1,0 (R * ea)^0.5 in the meridional direction” ?
-Is the primary local membrane stress PL a bit related to a secondary stress? Secondary stress is defined as for example “stress developed by constraints due to geometric discontinuities”. But is it not also commonthat the reason for a local primary stress being higher than surrounding general primary membrane stress is due to ”geometric discontinuities”?
BR/Micke
Question:
Question:
BR/Micke
