I have encountered a problem when calculating the allowable stresses for bolts made of A2-70 material.
In a formula 5.2.2-1 of EN 13480-3 it is stated to use the second formula if Rm,t is available.
For temperature of 20 °C the ff value is determined acc. to the second formula, becauseRmt is known for 20°C.
This leads to higher allowable stresses at higher temperatures, because Rmt is not known and the value is calculated according to the first formula.
For example, allowable stress at 35 °C is much higher than allow. at 20°.
Has anyone approached this problem before and what would be the advice on how to proceed?
Thank you for your time!
Kind Regards,
Tomislav Begic
Kind Regards,
Tomislav Begic
