Fran67
Industrial
- Jun 26, 2019
- 28
Hello everybody,
I'm working on a special design flange with metal-metal contact.
The flange design comply with ASME VIII div 1, but the effects of the temperature on the parts expansion is critical. (It leaks if we don't consider the temperature effect)
I found the standard EN1591-3 (last version : 2007) which could be very interesting to estimate the effects of the temperature (combined with external forces).
I would like to know if someone has already worked with this standard? I'm confused because I don't find compliant results when I apply the standard:
-> I suspect some errors in the formulas of the standard, what do you think?
-> It would be very interesting for me to get a sample of a calculation note to compare with mine.
-> Do you know a software proposing a calculation according to this standard?
Complementary information: the root purpose is to avoid a FEA study.
Thank you for your help
Fran67
Fran67
