The enercalc tool gives this warning on retaining walls:
Thanks.
The above calculation is not valid if the heel soil bearing pressure exceeds that of the toe,
because the wall would then tend to rotate into the retained soil.
But What it means? and how must it be addressed?because the wall would then tend to rotate into the retained soil.
Thanks.
