Engineering software tool for analyzing widely varying loads on a structure
geesaman.d
I have an engineering problem that involves the stress of a shaft system with multiple load points and the loads have varying direction and magnitude. The variation over time is *not* cyclic - it is random. If you ignore the variations for a moment, this is an easy linear structural FEA.
The problem is a Miner's rule fatigue calculation but because there aren't fundamental frequencies, it is very subjective and manual to sort out the variations that stack up very quickly.
Can anyone advise of a software tool that can manage the Miner's rule fatigue calculations and varying load cases? Bonus points if it will set up and run the numerous FEA load cases.
David
I might have my own answer: break up the load vs time history using ASTM E1049 methods and apply a tool like Fatigue+ to process the load cycles.
If I choose the right cycle counting algorithm I could limit my FEA runs to a handful.
The trick (as always) is to settle on material properties for ultra-high-cycle (gigacycle++) fatigue to suit our case.
ncode may help ?
sounds like ...
run an FEA with all the various loads
create a stress history at each surface node
convert these to rainflow, then cumulative damage
Take a look at CAEFatigue by Hexagon. It allows variability to be introduced into the problem.
