Engraving non standard part attributes 1
Raghu Jagannathan
I am new to this forum as a user but I have found it immensely helpful in solving my problems. I wanted to post a question that I did not find an answer yet.
When you create a part, there are several properties that can be assigned to it - dash number, revision number, etc.
If I am creating a part and I want to engrave, say, the revision and the dash number in it, how do I create an expression to link it?
I found this previous thread, which was helpful to link the part file name but not other part attributes.
Thanks.
create an expression with:
ug_askAttrValue_("", "PART_ATTRIBUTE", "my_attr")
replace "my_attr" with your desired attr.
Gelson Z. Nicoletto
Eng. Supervisor
Mould Desing
Brazil
The attribute system was cleaned up around NX 8 or 9; it works closely with the expression system now. I don't recommend using the "ug_askAttrValue" because updates might be a bit unpredictable. Instead, when you create an expression, right click on the formula field and choose "edit..."; from here you can reference a part or object attribute.
www.nxjournaling.com
