elinah34
- Aug 19, 2014
- 149
In ISO Envelop requirement is by definition a perfect FORM at MMC condition. I couldn't figure out if it also limits the feature's form tolerance in any other case.
For example, if I have a hole with a size dimension of 100+/-1 with E modifier - the form should be perfect at MMC, i.e 99 mm diameter. But what is the allowed deviation of form if the size is otherwise, e.g at LMC, i.e 101 mm diameter?
If you can refer me to a good source that explains it, it will be great.
