Epoxy Primer
royalra
New member
Aug 18, 2003
10
I'm looking to identify a diester-resistant epoxy primer equivalent to Shorts Aircraft specification P-Spec (?) 910.
Is anyone familiar with that spec, and if so is MIL-PRF-23377 equivalent? Or is there another Mil-spec more appropriate?
Russ Royal
r.royal@aeromec.com
Russ,
The Shorts P.Spec (Process Specification) 910 tells you how to apply primer - not what the primer is. Depending on the contract that you're working on, there is probably an SMS (Shorts Material Specification) or BAMS (Bombardier Aerospace Material Specification) number referred to - this is what you should be looking an equivalent / alternative to.
The quickest way to check may be to contact Shorts directly.
Rikman
If Beethoven had been killed in a plane crash at the age of 22, it would have changed the history of music...
and of aviation.
