Hossein3ds
Student
- May 12, 2022
- 3
Dear All,
Has anyone encountered the following type of error in Abaqus? I am performing a partially coupled thermo-mechanical simulation, in which the thermal load is applied as a predefined field in the mechanical analysis, using data imported from the .odb file generated by the thermal simulation. Although I have successfully conducted this type of simulation multiple times, I occasionally encounter the error described below. I am uncertain how to resolve it, as it is quite unusual. Notably, I have specified both the step and increment numbers in the predefined field load.
I would appreciate it if anybody could help me.
Error in job Job-3: Requested increments were not found in the output database C:/Dataset Abaqus-2/Case-24/1/Job-1.odb. Cannot read Nodal temperature data.
Error in job Job-3: No Nodal temperature data was found in the output database C:/Dataset Abaqus-2/Case-24/1/Job-1.odb for requested steps and increments.
Error in job Job-3: No Nodal temperature data was found in the output database C:/Dataset Abaqus-2/Case-24/1/Job-1.odb.
BR,
Hossein.
BR,
Hossein.
