error message from abaqus.
Oluwakay
83
Hello Everyone,
I an trying to convert my failed material into particle and I have the error message " THE CONVERSION CRITERION PARAMETER CAN ONLY BE USED IN COMBINATION WITH SPH CONVERSION = PER ELEMENT." I really don't know where to set this up. I have Abaqus/CAE 2023 model.
I will use any help I can get.
Thank you so much!
You can add it manually to the exported .inp file using any text editor. Or via the Keyword Editor available in Abaqus/CAE but it might be better to do it after exporting the input file.
