Error Running eigensolver (ABAQUS/standard rank 0 encountered a SEGMENTATION FAULT)
jrb26
Student
Apr 1, 2025
1
Hello, I've encountered the following error when running a natural frequency eigensolver job.
Error:
---------- RUNTIME EXCEPTION HAS OCCURED ----------
*** ABAQUS/standard rank 0 encountered a SEGMENTATION FAULT
I have a single mesh (converted from an STL into geometry - no issues with meshing) with a simple encastre BC on one of the faces of the geometry.
I am currently using a computer with an AMD Ryzen 5 1600x w/ 1060 3gb. However, I have got the exact same model and job configuration to work on a different computer with an Intel i7-11370h w/ Nvidia MX450. Could this factor in? Does Abaqus not like AMD CPUs?
For my current setup, I installed Abaqus on a my E:\ drive rather than my C:\ drive (as I was low on space), which I thought I did correctly, however, looking at the EXCEPTION file that was created, it looks like the job is trying to access directories that are located on my C:\ drive. Is this relevant? I only have ~3GB left on my C:\ drive, perhaps its running out of memory?
I'm relatively new to Abaqus, so any suggestions would be really helpful, thanks in advance.
EXCEPTION file:
<Description>
</Description>
<Context>
LANCZOS SOLVER
</Context>
<Phase>
Exec | ProcDriver | Execev | Lancsol | Eigensolver | DmpSolveDistributeOper
</Phase>
<Callstack>
  1. ABQSMABasShared.dll vsnwprintf_l
2) standard.exe DSYSysHashTable::Replace
3) ntdll.dll RtlRaiseException
4) ABQSMAEqsSolCore.dll sol_SolverSparseData::MapForSolver
5) ABQSMAEqsSolCore.dll sol_DmpSparseSolver::DistributeAndMapOperator
6) ABQSMAEqsSolCore.dll sol_DmpSparseSolver::FctFwdThreadTask
7) ABQSMAEqsSolCore.dll sol_DmpSparseSolver::FactorizeForward
8) ABQSMAStsSlvUtils.dll lnz_DmpLanczos::LanczosInitialFactor
9) ABQSMAStsSlvUtils.dll lnz_DmpLanczos::Solve
10) ABQSMAStsSlvUtils.dll lnz_Eigensolver::Solve
11) ABQSMAStsSlvUtils.dll callLanczos
12) ABQSMAStaCore.dll lancsol
13) ABQSMAStaCore.dll execev
14) ABQSMAStaCore.dll execproc
15) ABQSMAStaCore.dll procdriver
16) ABQSMAStaCore.dll substep
17) ABQSMAStaCore.dll exec
18) ABQSMAStaCore.dll std_main
19) standard.exe BasicLicenser::preHeartbeat
20) standard.exe BasicLicenser::preHeartbeat
</Callstack>
<Memory>
<Current> 6182 MB </Current>
<Resident> 5544 MB </Resident>
<Physical> 16316 MB </Physical>
<Limit> 14684 MB </Limit>
<Accessible> 16316 MB </Accessible>
<Allocator> DL </Allocator>
</Memory>
<Directories>
<current> C:\Users\bob\AppData\Local\Temp\jrb250_natfreq_4e9_03_850_7536 </current>
<indir> E:\temp </indir>
<outdir> E:\temp </outdir>
<tmpdir> C:\Users\bob\AppData\Local\Temp\jrb250_natfreq_4e9_03_850_7536 </tmpdir>
<temp> C:\Users\bob\AppData\Local\Temp </temp>
</Directories>
<Installation>
<Version> 2020 6.20-1 </Version>
<Build> 2019_09_13-18.49.31 163176 </Build>
<Executable> E:\SIMULIA\EstProducts\2020\win_b64\code\bin\standard.exe </Executable>
</Installation>
Message file:
1
Abaqus 2020 Date 01-Apr-2025 Time 20:06:56
For use by REDACTED under license from Dassault Systemes or its subsidiary.
less than 1.5Hz
STEP 1 INCREMENT 1 STEP TIME 0.00
S T E P 1 C A L C U L A T I O N O F E I G E N V A L U E S
F O R N A T U R A L F R E Q U E N C I E S
THE LANCZOS EIGENSOLVER IS USED FOR THIS ANALYSIS
SYSTEM DATA WILL BE WRITTEN TO THE .SIM FILE
Abaqus WILL COMPUTE UNCOUPLED
STRUCTURAL AND ACOUSTIC MODES
ALL EIGENVALUES IN THE SPECIFIED RANGE WILL BE EXTRACTED
HIGHEST FREQUENCY OF INTEREST 1.5000
MAXIMUM NUMBER OF STEPS WITHIN RUN 35
BLOCK SIZE FOR LANCZOS PROCEDURE 7
THE EIGENVECTORS ARE SCALED SO THAT
THE GENERALIZED MASS IN EACH VECTOR IS UNITY
THIS IS A LINEAR PERTURBATION STEP.
ALL LOADS ARE DEFINED AS CHANGE IN LOAD TO THE REFERENCE STATE
EXTRAPOLATION WILL NOT BE USED
CHARACTERISTIC ELEMENT LENGTH 0.193
DETAILS REGARDING ACTUAL SOLUTION WAVEFRONT REQUESTED
DETAILED OUTPUT OF DIAGNOSTICS TO DATABASE REQUESTED
PRINT OF INCREMENT NUMBER, TIME, ETC., TO THE MESSAGE FILE EVERY 1 INCREMENTS
COLLECTING MODEL CONSTRAINT INFORMATION FOR OVERCONSTRAINT CHECKS
COLLECTING STEP CONSTRAINT INFORMATION FOR OVERCONSTRAINT CHECKS
CHECK POINT START OF SOLVER
COMPUTER PRECISION USED BY ABAQUS 2.22045e-16
CONVERGENCE CRITERION FOR LANCZOS RUN 1.81899e-12
NUMBER OF EQUATIONS 1871289
NUMBER OF UNRESTRAINED DEGREES OF FREEDOM 1866642
HEURISTIC SCALE FOR THE FIRST NONZERO EIGENVALUES (PROBLEM SCALE) 3.40542e-03
INITIAL SHIFT VALUE 0.00000e+00
NUMBER OF CPUS USED BY DIRECT SOLVER 1
