apal21
- Apr 11, 2020
- 53
I am trying to make a model where I apply a surface heat flux load to a disk. For this, I need to define a surface, which I to do. The load is defined properly, as shown by the green arrows in the attached photo. However, when I run the job, I get the same error for all the elements in the set concerned:
LOAD TYPE S IS NOT VALID FOR ELEMENT TYPE C3D8R
Can someone please explain why?
