engmechs
- Apr 22, 2005
- 80
Hi all,
I am a mech. engr. & just received a project to deal with ESD issue. A charger/cradle device had a cutout at the back side for program/ testing purposes. But this caused the ESD problem. Right now, a rubber seal is applied to block the gap but didn't meet ESD req't. Testing results found the min. distance between PCB board & test probe is at least 8mm ! But physically I saw the PCB is actually about 3 mm away from the plastic surface.
The rubber seal idea works, when the PCB sits far away from cutout. But since the plastic tooling had been made, modifications to the tooling is costly.
Is there any way to resolve this issue, from a quick fix point of view? Any sites to do research on this topic?
My initial thoughts:
Make the rubber seal larger, to meet the 8mm distance req't.
Metallic/ conductive coating be a possible solution? (Applied to inside cover surface)
I really want to know on this topic, as this kind of issues may come up more often. Any comments are welcome.
Thanks in advance.
engmechs
Thanks in advance.
engmechs
