hotmailbox
Context: I am developing (hired a CS student to be exact) Wood Design Addin for Etabs (curved or straight beams, posts, studs, braces, joists, or whatever being covered in NDS). Since all newly created woood members in Etabs can't be assigned to steel or concrete for design, the Auto Live load Reduction won't work for these members and you can't get member design forces (which includes Live Load Reduction). That means I have to do it and below is what I am trying to do to estimate tributary area for a beam. For columns or posts, it's easy and straight forward. I'd love to hear everyone's feedback.
Assumptions:
1. Beams shall be broken into pieces ends of which are either free end (truly free or supporting a secondary beam) or support (column or connected to a stiffer beam). Beams shall be modeled this way.
2. So each design member shall be considered as either end supported one or a cantilever one.
3. Live load to be 40 psf. It can be whatever but for the simplicity, assume it's 40psf.
4. Floor loads shall be assigned to one-way floor plate which distributes load to joists and beams based on joists spacing and point loads onto beams.
For beam pieces "supported" at each end: Total live load supported by the beam = Sum of Absolute shear value at each support due to live load. The tributary area = Total live load/40psf.
For cantilevered beam: Total live load supported by the beam = Maximum shear in the beam due to live load. Tributary area = total live load/40psf.
From ATT above, use KLL = 2 to calculate the live load reduction factor per Code Equation.
Below are my questions:
1. Is this too conservative for continuous multi-support beam because we may not see KLL*ATT ever greater than minimum? I have not figured out how to estimate the total live load based on the shear diagram of the beam? (Maybe = Absolute shear at each end + shear jump at each support but I have to think how to code to differentiate shear jump at supports and shear drop at concentrated loads).
2. How do Etabs or other software estimate live load reduction? I would assume it uses the same approach to estimate the tributary area for each member.
Assumptions:
