jraef
- May 29, 2002
- 11,332
Can anyone share some shortcuts to estimating inertia on older machines for which drawings and data sheets are not available? I need to come up with a replacement braking system for older candler roller machines and the machine mfr is long gone. My fall back position is that since it starts across the line, I can scope the starter to determine the acceleration time from a stop, then using the motor data to determine starting torque, extrapolate the likely inertia of the entire system. Worst case scenario I end up estimating higher and over-doing the electronic braking. But has anyone used something I haven't thought of?
