tngv752
- Sep 16, 2004
- 91
Just some question about the way to input load and material.
-Can I input many different concrete material into Etab such as 25MPa, 0MPa,40MPa and 50MPa concrete and steel and timber ? It look like Etab default only 1 concrete and 2 steel materials only. I cannot add more material.
-Can I input line load and point load onto a shell element ?
I dont see any function in menu to help you to input line load onto shell element.
Do you other way to do it by creating point or line element ?
Thanks.
Thanks.
