eng.chix
- Jun 22, 2022
- 9
I'm modelling a 6 Storey concrete structure in ETABS. Since the loading requirements are fairly unbalanced and variable, I've introduced numerous 'none' slab properties to apply these variable loads. It appears as though these none properties have caused issued with the model run as I get error messages each time stating that there are area load transfer warnings. These warning always coincide with these none slab properties.
1. Do I worry about these? Or is it just a warning saying that I have these none properties, but that it does actually take them into account when it runs the model?
2. Are there tricks to applying these types of non-uniform loads other than how I've been applying them?
I appreciate any feedback! Thank you!
