Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Well thats what the piers are going to report in a response spectrum analysis.Can etabs pier labels be used for response spectrum results, where the +be/-ve sign is lost in the SRSS?
You're required to interpret the results, i.e. whether for a given direction of loading you're dealing with tension/compression and what moment applies at the same time (for example moments for each direct could be different especially after considering gravity loads). For a symmetrical structure your results will be a matching tension and compression action. You need to determine if the positive or negative moment goes with tension or compression action by understanding what your structure is doing and how the forces are being distributed.Can the pier labels adequately convert the absolute resulted at each end of a wall into tension compression resultants?
