ETAP Creating Single Line Diagram (MV Network) 1
PoliPoliCarps
35
I have been trying to create a single line diagram
I have the following questions. Please help. huhu
(1) Where can I found a Resistance Resistor Starters for Medium Voltage in ETAP?
(2) Where can I found the Load Break Switch? (Non-Fuse Type)
I really appreciate who will help.
Thank you in advance
Read more:
See reply on each query;
1) The RR starter type is available in the motor element editor. You may just select Induction or Sync. AC Motor on OLD plan. In the motor editor you can find "Start Dev." tab sheet where you can select type of start for your selected motor.
2) Load Break Switch - In ETAP, there is no specific element/device for LBS but you can use (I believe) normal single throw switch element and then you can configure it as you want such as voltage, amp. rating, rating, BIL, etc. also interlocking
Hope above is helpful
