ETAP - GE Power breakII - Library
NickParker
420
The Circuit breaker type is ICCB - GE - POWER BREAK-II
ETU Model - Entelliguard GB108L3XXXFXXXX.
I could not find this model in ETAP Library. I found some entelliguard trip units in ETAP Library, However, the band setting is very limited in this, but in the manual, I could find around 20 band settings for long time pickup.
Can anybody guide me to find the correct model in the ETAP Library?
Attached are the screenshots of ETAP which I found.
 https://files.engineering.com/getfile.aspx?folder=0cde4914-585c-41f1-ac6c-825a9adb0c26&file=ETAP_1.png
It may not be in the library. But best option is to contact ETAP tech support if you are under maintenance.
