5747hazel
- Dec 28, 2019
- 43
here are is a situations I might run into
say as an engineer you are hired by a employer who doesn't have a license to provide engineering services to public. the employer never ask you to provide any engineering services to public under the employer's name. but some time the employer would ask you to engineer something for the employer itself. say to build a little structure in its parking lot or in a land it purchased. is it ok for you to do the work and sign and seal the document? even do you have to sign and seal the document you produce it is only for your employer. or even is it ethical to do the work?
I personally always worked for some kind of engineering firm for my whole life. never needed to deal with a situation like above before. thanks
