Colleagues,
Alloy is 35Cr45Ni (no ASTM spec to reference).
1. Furnaces are being erected and it was noticed that some of the tubes have multiple rust spots, typically these results from carbon steel contamination.
I'd like to hear your expert opinions on expected damage mechanisms if carbon contamination is not removed. We think that these rust spots will likely carburized and some carbon will tend to form carbides with chromium. These chromium carbides will affect high temp properties of alloy (ex: creep, carburization resistance).
2. Second issue that was noticed in regards to galvanized scaffolding being used. We believe that if galvanized scaffolding comes in contact with this alloy it will cause LME due to zinc contamination.
is there a field test that ca be used to detect Zn on this alloy?
Cormet
lmE
Cormet
lmE
