Fran67
Industrial
- Jun 26, 2019
- 27
I have a question about the requirement of Eurocode 3 (Steel structure) part 1-10: Material toughness and through-thickness properties.
This part of EC suggest formulas to choose the quality (JR/J0/J2...etc) of a steel part according to some criterias:
- the thickness of the part
- the reference temperature
- the tensile stresses vs. the tensile strength of the material
If I consider the EC requirement, I can choose a S235-JR (Charpy test 27J at +20°C) steel for a mechanical part at -20°C ref temperature if there is never tensile forces and tensile stresses on this part.
BUT the code does not specify if we have to consider shocks for the steel class definition. (Shock -> Screw falling, Hammer falling during a maintenance phase, shock during transportation..etc)
I've already heard some engineers which do not use EC-3 formulas and consider that the Charpy test must be performed at the minimum ref/ambient temperature. (In example above, it would be a S235-J2 for -20°C ambient T°)
An other example: a lifting lug
According to EC-3/1-10 formulas, I can choose a S235-JR lifting lug at -20°C ref temperature for my machine because the traction force during lifting is very low (10% of S235 tensile strength).
But is the case "the slings/shackle knock against the lifting lug (shock) during the lifting" covered by the EC-3/1-10 requirement?
What do you think about these two interpretations?
What are the requirements of american codes about this subject?
Thank you for your responses,
Best regards,
Fran67
Best regards,
Fran67
