Mohanlal0488
- Jun 26, 2020
- 103
Greeting Fellow Structural Engineers
I generally use SANS10162 for most of my steel work designs, however I do use AISC and BS/EN standards for design aspects not covered in SANS10162.
For beams SANS10162 requires that the lateral restraint be provided on the compression flange, however this is as far as this statement goes. Does anyone know of any literature or codes of practice which actually deal with the mathematics behind this?
For example, I would assume that if one has a relatively deep beam (supporting beam), with tie beams (much smaller then the supporting beam) and bracing such that it is positioned on the tension side of the supporting beam, this would not constitute as a lateral restraint by definition, however I think that it would offer restraint to some degree, and I would be interested to know how this could be taken into account.
