Assume I have an enclosure, say 4ft x 3ft x 3ft which is closed but not completely airtight. There is a small cylindrical tank of ethanol, say 1.5ft D x 1ft H, with a 1.5 inch pipe sticking out the top, open to the atmosphere (enclosure space). The liquid ethanol level in the tank is about 8” high. The surroundings are at 70F and 14.5psia.
Ethanol vapor density is higher than air, so evaporated ethanol should settle at the bottom of the enclosure. As far as I understand, the ethanol should continue to evaporate until equal concentrations of ethanol exist in the liquid and vapor state inside of the enclosure such that equilibrium vapor pressure is achieved (although this likely will never completely happen, as the enclosure is mostly, but not completely airtight).
But what is the driving force pushing the ethanol vapor out of the container? Pressure build-up that overcomes the surrounding air pressure? Diffusion due to concentration difference? I’ve heard argued that ethanol vapor will just sit in the tank and not build up in the enclosure, but we know intuitively that this isn’t correct (leaving an open gas can in a closed garage will fill the garage with gas fumes).
Also, what would be the effect of pressurizing the air in the enclosure (low pressure, say a fan blowing in atmospheric air from outside). Would this reduce the escape of ethanol from the tank in that case?
Thanks.
Thanks.
