I recently had someone bring up that they typically detail continuous poured walls with an even dimension (whole feet) from top of wall to top of footing. I've always detailed using a 12" thick footing for small structures and used the wall height below grade to achieve frost depth (for example, 6' above grade, 2'-4" below grade then the footing). This results in a 'total' poured wall height with dimensions like 8'-4" or 6'-6".
From a constructability standpoint, should this be designed as a 8' wall with a thicker footing, simply to achieve an even dimension on the wall? Or even a 9' wall with a 12" footing and push the bottom of footing below frost depth? I've never had a contractor push back on the way I've done it up until now, so I'm wondering what standard practice is. I don't want to waste concrete, but don't know if that makes construction difficult.
