EmmanuelTop
Chemical
As a consequence of plate failure in a Plate & Frame heat exchanger in Amine unit, there was a long (and virtually impossible to detect) leak of cooling water into Absorber wash-water stream. Bottom line: contamination of circulating Amine with Sodium, resulting in deposition of Sodium Hydrogencarbonate salt inside Absorber, inside instrument sensing lines, on the standby pump impeller, etc. It's a mess.
The plant is located in western Balkans region, there are no service companies around who could do reclaiming in-situ. Changeover of the solvent is about 0.5 to 1.0 Million EUR, hence should be avoided as much as possible.
Any hints?
There is no such thing as "common sense" - Apollo RCA
Any hints?
