Expert advice seeking 1
cdafd
Specifier/Regulator
This may be a question for some that have been in the industry, for awhile.
I saw these at a hotel.
They also had bulb sprinklers in other areas.
I have not seen these before. Just seeing if anyone else has??
Maker?? And maybe model?
They were in a bar area
For what it is worth I started my sprinkler career in 1975 and I have never seen anything like that.
Are they are old video cameras or old heat detectors? Do not look like any sprinkler I have encountered since doing this since 1979.Time for the sprinkler contractor to give it a look see. Long shot any spares in the box?
I was visiting/ snooping at the hotel.
Not in my ahj.
Could be heats, but the adjoining area have bulb sprinklers, and open to this area
And these things appeared to be spaced per sprinkler spacing
Thought maybe early concealed or institutional like sprinkler??
Just wondering
Travis
No
The pictures attached are of the room.
They were spaced thru out.
The rest of the building had fire sprinklers
Plus appears there are mains on one side of the room.
I should have looked at those closer, to see where they run.
Miami
Thanks, you think you have seen almost every design of a sprinkler,,,, than one comes along, and you say what is that???
Thanks, I have seen institutional, just this one does not look like it would do anything!
Mystery solved
