Export dimension coordinates from a drawing to Excel by catscript
Froufrou
Aerospace
BE
Hi everyone,
Glad to join the community !
I have been searching here and on the web how to extract the coordinates of a drawing dimension, I hope you guys could enlighten me.
The goal is to export to Excel the dimensions from a drawing as it is done by the Marc Litzler catscript ( and I want to add the position of the dimension according to the drawing frame.
I guess it might be something like :
Code:
Dim xpos as double
Dim ypos as double
xpos = MyDimension.x
ypos = MyDimension.y
myworksheet.cells(i + 1, 7).Value = xpos
myworksheet.cells(i + 1, 8).Value = ypos
(This is in a loop, looping the selected dimensions)
I have also tried with MyDimension.AnchorPosition and others but none works.
Does any one know how to get that ?
Then, from the (x,y) position, I intend to attribute a frame position like C5 for example.
Thank you for your time !
François
Note that this code works if MyDimension refers to a text instead of a dimension.
