exporting point coordinates relative to assembly axis.
pravs
Hi,(
I am having a part with multiple instances and need to export coordinates of points created on one part (reflecting on the other instances as well)relative to assembly axis as shown.Currently I am able to export only one set of coordinates .
the code is used is
Sub CATMain()
Set objexcel = CreateObject("Excel.Application")
objexcel.Visible = True
Set objWorkbook = objexcel.workbooks.Add()
Set objsheet1 = objWorkbook.Sheets.Item(1)
objsheet1.Name = "Points_Coordinates"
Dim coords(8) As Variant
Set Selection = CATIA.ActiveDocument.Selection
'Selection.Search "( CATPrtSearch.Point),all"
Selection.Search "NameInGraph=*Point*,all"
For i = 1 To Selection.Count
Set Element = Selection.Item(i)
Set ptt = Element.Value
ptt.Getcoordinates(coords)
objsheet1.cells(i + 1, 1).Value = ptt.Name
objsheet1.cells(i + 1, 2).Value = coords(0)
objsheet1.cells(i + 1, 3).Value = coords(1)
objsheet1.cells(i + 1, 4).Value = coords(2)
objsheet1.cells(i + 1, 5).Value = Element.Name
'this is for non-isolated Points
Set parentObject = ptt.Parent
Do
If TypeName(parentObject) = "HybridBody" Or TypeName(parentObject) = "Body" Then
objsheet1.cells(i + 1, 5).Value = parentObject.Name
Exit Do
Else
Set parentObject = parentObject.Parent
End If
'safe check
If TypeName(parentObject) = "Part" Then
Exit Do 'you've went to far up and reached the Part itself.
End If
Loop
'this is for isolated points
If objsheet1.cells(i + 1, 5).Value = "" Then
bFound = False
Set oPart = CATIA.ActiveDocument.Part
'temporarily rename the point so the proper point is retrieved.
tmpPointName = "tmpPoint." & i
Point.Name = tmpPointName
For ix = 1 To oPart.HybridBodies.Count
Set oMyHBody = oPart.HybridBodies.Item(ix)
For jx = 1 To oMyHBody.HybridShapes.Count
Set oHShape = oMyHBody.HybridShapes.Item(jx)
If oHShape.Name = tmpPointName Then
'this is my Point. get the parent's name
objsheet1.cells(i + 1, 5).Value = oMyHBody.Name
bFound = True
Exit For
End If
Next
If bFound Then Exit For
Next
Point.Name = objsheet1.cells(i + 1, 1).Value
End If
Next
